Old 08-31-2009, 08:07 AM   #1
JFP in PA
Originally Posted by silbord
Since the engine temp gauge above 180 is not normal on a Boxster, what do you think the causes of this? I read some of your posts regarding T-stat 180LN vs 160LN. Should I change T-stat 180 LN to 160 LN in order to lower the engine temp?
The very first thing you should be doing is get the car to someone with an OBD II scanner capable of real time data capture (PID); have them check what your water temp really is at before you puke something major.
You could have a bad dash gauge, temp sending sensor, water pump, externally blocked radiators, or dead thermostat; you need to start eliminating items one at a time rather than just swapping out parts……………
