Thread: Water Pump
Old 08-29-2009, 06:02 PM   #13
pk2
jmatta
In all sincerity, why would Porsche knowingly put a thermostat in that they must know (if you do) is much hotter and is therefore going shorten the engines life ?( As if the motor wasn't a bit of a disaster as it was.) And if it's running at 210, why not say so instead off consciously papering over the dash gauge to read 180?.
Do you think they play the same hi-jinx with the GT and turbos that, as is stated in this thread , are supposedly running at 140?
Also , cooler oil sounds nice (especially on a hot day (grin)) but what difference dose it make...it breaks down sooner and might be harder on rubber seals but what else that isn't compensated for? These things have a pretty aggressive oil change regiment which should mitigate any oil degradation, and rubber seals arn't your fathers
This isn't rhetorical and I'm not being a smart a__, I'm truly curious.
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
