With any luck your dealer will not have put on the front license plate and you'll have the option of whether or not you want those holes drilled in the front.
Congrats! Take pictures.
What options did you get?
So far I think I might have a small rattle from the passenger door, but I can't tell for sure. Other than that, rock-solid.
You might want to check the battery cover though--it's not a very well-made piece and its a little bowed on mine at the edges--looks sloppy. I looked under the hood of others on the lot though and they all had the same problem to some degree.
Oh also, they forgot to poke the hole in the carpet for my floor mat peg--you might check that before driving off.
