08-26-2009, 07:26 AM
#8
Originally Posted by jsceash
Could you be more speciffic.
Most “lift by the front wheels” tow rigs will not clear your front under tray and will cause damage to it and the radiators, and lifting the front high can actually make the rear hit the ground, usually at the exhaust tip area. Lifting the rear has the same issues, only now the truck is hitting things around the engine and exhaust, and the nose is dragging on the ground. This why your nose sometimes hits when pulling into a steep driveway entrance; same issue.
Find a flat bed or be prepared for large repair bills……………
And, it is spelled "Boxster".............
