Old 08-23-2009, 11:59 AM   #15
sb01box
Originally Posted by 70Sixter
One simple possibility is that the new rear tires are not broken-in and are still a bit slick. Especially if you don't drive hard.
This would give less rear stick and therefore more oversteer since the rear would try to slide out while the stickier (broken-in) fronts hold their own.
I would not make any suspension changes until I got the rears broken-in and played with the air pressures.
You need a good baseline going into changes.
thanks, this may be the source. I had dismissed this since many un mount and flip the rear tires to get longer tread life due to high negative camber. but then, they may not be pushing their car to notice.
I would like to install stiffer sway bars but keep the ride height/springs - only DD and weekend drive through the mountain from time to time.
I've been searching the forum for sway bar information. as it stand at this time, I'm leading towards M030 S front sway and Tarett 18.5 mm adjustable rear.
thinking is that this will enable me to alter the "stiffness" front/back by changing the setting of the back. Amateur here - very green!!
sb01box is offline   Reply With Quote
