Old 08-23-2009, 11:48 AM   #14
70Sixter
One simple possibility is that the new rear tires are not broken-in and are still a bit slick. Especially if you don't drive hard.
This would give less rear stick and therefore more oversteer since the rear would try to slide out while the stickier (broken-in) fronts hold their own.
I would not make any suspension changes until I got the rears broken-in and played with the air pressures.
You need a good baseline going into changes.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
