Those door pocket lids peel easily when you get sunscreen on them, as there is an agent in the sunscreen that strips the thin layer on the lid. I was tired of it happening so I had the lids painted to match the exterior of my car and then clearcoated. The lids are easy to remove.. all you have to do is lift them to the up position, and then you'll see two hinges. Use a hole punch or large paper cliip to push the plastic pin thru the hinge and then pull them out with a needle nose plier. The rear hinge has a spring so be careful to remove that spring first before pulling off the lid completely.
If you want to strip the old thin plastic layer off prior to painting the lid or recovering in leather, just run them through the dishwasher, and the film will come right off.
