Old 08-20-2009, 07:12 PM   #11
lardog
If you really think so, perhaps you should give Scott a call.............there are multiple traps built into the DME, including comparing the run time clocks between the airbag computer and the DME, which will reset every time it is re-flashed, while the airbag unit does not...........
There is also a type of "Check Sum" algorithm in use that does not count characters, but assigns values to each character and then sums those values; there by making the total number of characters irrelevant..........
This topic has been beaten to death on multiple websites.
Sorry, you are off base on this one...........and rude besides........
the run time clock DOES NOT RESET!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!
lardog is offline   Reply With Quote
