08-20-2009, 10:40 AM
#2
Originally Posted by lardog
BULL ****************!!!!!!
If you really think so, perhaps you should give Scott a call.............there are multiple traps built into the DME, including comparing the run time clocks between the airbag computer and the DME, which will reset every time it is re-flashed, while the airbag unit does not...........
There is also a type of "Check Sum" algorithm in use that does not count characters, but assigns values to each character and then sums those values; there by making the total number of characters irrelevant..........
This topic has been beaten to death on multiple websites.
Sorry, you are off base on this one...........and rude besides........
