Old 08-20-2009, 07:52 AM   #3
JFP in PA
Originally Posted by ddb
A The other tricky thing is you have to use a special tool to remove and install these pulleys. This tool uses an XZN 12-point socket to engage and hold stationary the center of the alternator shaft and a 31 spline socket to tighten or loosen the pulley on or off the shaft.
Where did you find the "holding tool" to remove the pulley?
