Old 08-19-2009, 04:53 PM   #1
Kirk
My local independent was going to charge me $600 to do two wheels, just the labor, no parts. I was going to pull the wheel carriers and bring them into the shop and have them simply press out the old bearings and then press in the new ones, maybe a 1 hour job. They still would not move from their $600 price. They have a book where they look up the time required for a job, multiply it by their hourly rate, and then give you a labor cost. It's that simple and most shops simply won't budge on that screwed up formula.
The shop you're using should not object to you bringing them the parts as long as they are good quality. If you can get them cheaper, then more power to you, right?
Also, do a search, we just discussed this. Someone else here wanted to rent the Pelican tool. They ended up buying the $80 Harbor Freight version. You should send them a PM to see if that worked, I haven't seen a report back.
Kirk
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
