it's smoking
Let me tell you what the car is doing. I was drving down the highway and the car started to somke really bad pulled over and towed the car home. read on the board about the AOS and replaced it. Now at ideal the car sounds great however there still small amounts of smoke and when you rev the motor it pours out smoke and oil is coming out of the tail pipe. the check engen ligth is not on and the car run great (other then the smoke) when I pulled the oil cap off I did here a hissing noise. it's not losing that much oil may down a quart if that. Even the oil light is off.
any other ideas on what I should look at? I'm sure it's time to take it to the shop but wanted to see if there was anything esle I souldh check before doing that.
