Old 08-18-2009, 04:30 PM   #1
rob76turbo
Can the coil packs fail from too much moisture
When installing the WEVO SS Engine mount, we took the opportunity to really clean around the engine (using simple green, brushes and lots of water). We scrubbed the heck out of it. However I cannot imagine that the engine / drivetrain runs that rough with the WEVO SS mount installed. Maybe one of the coil packs failed or shorted out? The motor sounds and runs very rough....like it is missing a cylinder or something. At idle, it seems fine, but as you run through the rev range, it has different vibration and sound characteristics. Strange.......
So my question, has anyone experienced a coil pack failure because they got the coil pack too wet? Would you get a CEL light if the car was running on less than 6 cyl? Perplexing.....
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
