Old 08-18-2009, 02:31 AM   #1
TEX
Smile same problem
Thats IT!!
ITS the AOS , I had smae problem lots of white smoke on acceleration up a ramp and on start up.
Get the AOS replaced quick smart.
Originally Posted by sb01box
if I am not mistaken, these are the front two o2 sensor fault. most likely due to excessive oil on the sensor.
there are may topic on smoke as it relates of AOS. if you search on smoke or aos you will find wealth of information. just need to go over it as it pertains to your car.
I recall that if it is AOS, then
not taking care of it may damage your O2 sensor and catalytic converter.
good luck
TEX is offline   Reply With Quote
