Old 08-17-2009, 03:08 PM   #1
JFP in PA
Failure of the oil to water heat exchanger is not uncommon, particularly if you car has the older “green” Porsche coolant in it. The oil cooler looks like this:
It is located on top of the engine, driver’s side rear, somewhat beneath the intake manifold runners. In the US, the unit sells for about $200. Changing it is a DIY, but you will need to totally drain the cooling system first. The swap out has been written up on many sites, so do a search…….
