08-17-2009, 02:17 PM
#23
Originally Posted by mptoledo
No, I pretty much think your wrong on that. The cup on the bottom is to keep debri and water from getting sucked in. Now how effective it is, well thats another question. If you really look at it, its obvious the cup is there for a reason, to keep crap out.
Look at what you are dealing with: Because of where the opening is located on the side of the car (well below the belt line), and because most of the air flow is thru the upper slats in the grill, any debris or water that entered would drop down and be collected in what you describe as a “cup”, directly in front of the opening to the intake system………..hardly seems as a good description for something to prevent the debris from getting into the intake; and if fact looks more like something to help it get sucked in………
It is a noise abatement device, nothing more…………….
