08-17-2009, 11:37 AM
#2
Originally Posted by Boxtaboy
I've heard that theory about the snork being placed there to meet the stringent sound limitations in certain countries, but I then wonder why that type of snork tube is inserted in many different types of cars, even domestic ones.... you find them in the older air cooled 911s, in Mazda pickups, all sorts of cars....they all have snorks leading to their intakes. Therefore, I would think that there was a reason for them being there (maybe one function is to further quell sound), but there has to be another benefit to them, no? In fact, I would bet that you could get the Boxster up to higher speeds without even realizing the louder noise of the desnork because the extra growl from the desnork doesn't even come on until after 4k+ rpms really. This is why I don't think the snork is there solely for the purpose of noise abatement.
Actually, it is for noise abatement, and different OEM’s handle the issue in various ways. We currently have a Nissan product in the shop that has two factory options: A really slick cold air system and a large diameter, low restriction stainless steel exhausts system. Because the car came from the factory with these, there are two small decals on the radiator support noting that “the car is not legal for export to certain European countries”, because both the intake and exhaust fail to meet “TUV noise standards”. The non option version of the same car has a plastic box in the intake system with a similar baffle to the one on the Boxster inside of it, if you disconnect the box; you get a pronounced intake “roar”, much like the cold air system has. Interestingly, the optional cold air system, which while simple, is beautifully designed, adds 8-10 HP at the wheels, and the exhaust another 10-12 over the standard stuff, so the addition of these does make a significant difference.
The Swiss must drive the OEM’s nuts with this stuff………..
