Old 08-17-2009, 07:59 AM   #1
ppbon
ppbon's Avatar
Originally Posted by naelec
Hello every Porsche's friends
After having read different post concerning noise, in the right rear wheel area, at low speed ,on bad road.....I am surprised that nobody mentionned possibility of brake shoe noise (hand brake,in the disc).......
Is it possible ?
Does anybody encountered this issue,please?
Thanks in advance
There are several components in the suspension that can cause what you describe.
I would start with the easiest to check and most likely part: The sawybar drop link.
The way to test is is to see if there's any play in the joint which wears out with time/miles.
Raise that corner of the car and undo the bottom nut securing the drop link.
Now you can handle it and determine if it';s worn or not.
Worn joints will be very loose and wobbly, whereas new ones will be very tight and hard to move by hand.
The OEM ones are about $100.
If you find that one side is worn, the other side is probably about to go too.
Happy Boxstering,
Perdro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
