Old 08-16-2009, 10:10 AM   #1
sb01box
Originally Posted by mikes_box
pulled the code reader up and came up with two codes... p1128 and p1130... any input...
if I am not mistaken, these are the front two o2 sensor fault. most likely due to excessive oil on the sensor.
there are may topic on smoke as it relates of AOS. if you search on smoke or aos you will find wealth of information. just need to go over it as it pertains to your car.
I recall that if it is AOS, then
not taking care of it may damage your O2 sensor and catalytic converter.
good luck
sb01box is offline   Reply With Quote
