Old 08-14-2009, 12:30 PM   #21
yellowboxster01
Originally Posted by mptoledo
I see in your profile thingy, you have the gahh glass window top. How do you like it? Where did you get it? I need a top as my window has a couple cracks on the plastic along the side.
I took my car into a shop that does tops and they ordered it and installed.
The problem with the GAHH glass window top is that the rear window is smaller than stock. I have to bend down a bit to see clearly out the back window. That said, if I had it to do over again I would buy an 03' glass window top and retrofit it onto my 01.
There's a thread here that someone explains everything involved with doing the conversion.
Aside from the rear window issues, the top is very well made and I've not had a problem with anything. It's been on for about 9 months now and is holding up excellent.
yellowboxster01 is offline   Reply With Quote
