Thread: Remove oil pan
Old 08-12-2009, 02:25 PM   #22
rob76turbo
Here is a thought; if you track or Auto-X your car, consider replacing the stock oil pan with the X-51 pan. It is available from both Sunset and Suncoast for about 199 and will help keep oil at the pick up tubes in fast corners. The pan requires a small modification, I was able to do it in 10 minutes with some snips and Dremel.
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
