Thread: Dash speakers
Old 08-11-2009, 05:46 PM   #28
drem914
The stock amp is 4 x 40w and they typically run the dash and doors.
the head unit runs the rears unless you have a 6 x 40 amp. you can tell by the order code in the front trunk what type of audio you have. If you did not have rears before putting these in, you probably have the 4 x 40. I suggest you trace the line outs and speaker outs to find out what is connected and where.
You may need to modify the harness connection between the jvc and the amp in the car. No telling what BB did, if you have to turn the front fade all the way up to get anything out of the rear. Hopefully they didn't switch everything around and set the dashes as the rears and the doors as the fronts
2001 Seal Grey, 2.7L
drem914 is offline   Reply With Quote
