Thread: Techno Torque 2
Old 08-10-2009, 10:05 AM   #1
ppbon
ppbon's Avatar
I made the switch from 10W40 ....
Originally Posted by Burg Boxster
Following Pedro's postings, hacks, explanations etc. for a number of years, I can tell you he made the switch to 10W30 for a good reason. If I recall correctly, it had to do w/ stopping the weeping from his RMS. Plus, the first # in the oil rating doesn't apply as much to his climate - south FL as the first # in the oil's weight rating is it's cold flow rating. Cold in south FL is just a tad bit different than cold here in PA (or OH) for 50 weeks or so of the year...
... (I've never used 10W30) quite a few years ago, as Burg says.
When my car developed an RMS leak, I decided to try a heavier blend (15W50) and it completely cured my leak.
I've been using it ever since.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
