Originally Posted by ChrisZang
check the microswitch on top in the center of the windscreen it might be stuck
Thanks--I found the problem--it was the top latch micro switch assembly--actually there are two micro switches in that assembly--both switches tested OK with an continuity tester BUT there was a bad solder joint on one of the two metal strips that connect the switch to the connector.
This link has details of what happend:
http://www.renntech.org/forums/index.php?s...c=10458&hl=
