					Originally Posted by Paul
				 You need to clear the code then turn the key on (without starting or touching the gas pedal) for about 90 seconds then turn the key off for at least 10 seconds.
 This code can be caused by:
 A loose connector at the sensor
 Corrosion on the connector
 Bad wiring from the sensor to the DME
 Bad sensor
 Bad DME
Paul sorry not clear on this. Is this how you shut off code or something you do after. If after please define purpose. Thanks is advance.
