Old 05-15-2005, 04:25 PM   #4
eslai
Originally Posted by SRA2005
i know that the cayenne has autoleveling installed. can somebody confirm this?
its so expensive to purchase litronic headlights. i know i can save money without having to buy the litronic headlights by retrofitting a headlight projector preferrably bi-xenon from a bmw 7 series or nissan maximas and fabricate it into a halogen headamp so it would look custom looking if not even better! I have done it to my car already. its $15 dollars to make a harness and 300 for the projectors and ballast with ignitors.
if i can find a salvaged boxster headlight i'll go into it try it out.
It's also illegal because the halogen reflector won't create the proper light pattern, nor will you be likely to get the lamp leveling hardware to work properly.
In short, you won't be D.O.T. approved, you'll scatter glare at people around you, you'll have an improperly focused light beam with possible poor illumination, and you'll be vulnerable to getting a fix-it ticket.
eslai is offline   Reply With Quote
