Old 08-04-2009, 05:06 PM   #3
mikes_box
if you're at the center of the 8 then you'd be running cooler than if you were between the 80... now if you're over the 0 then running a little hotter... if so make sure you keep your bleeder valve on a day or so to release any air in the system and then check coolant level and fill... after the day or so drop the bleeder valve back down...
mikes_box is offline   Reply With Quote
