Thread: Rough Idle
Old 08-04-2009, 11:49 AM   #10
mptoledo
I just did a search on here with the phrase "rough idle" and found quite a few. Look under
http://www.987forum.com/forums/search.php?searchid=767526
check out the "cold starting" thread.
With 15k miles and if it worked fine before and now it doesn't, process of elimination says something happened. I know **************** happens sometimes but probability says it was them and not chance. I doubt you all of a sudden got carbon build up. It sounds like something computer or system related. Possible o2 sensor. I changed my plugs(probably first time) at 60k miles and that fixed my slight idling problem.
Good luck and don't take no for an answer
I'll take my Guns, Religion, and Money; You can keep the "CHANGE" B.O.!!
SO, GROW A PAIR NANCY AND DRIVE IT LIKE YOU STOLE IT!!
http://i826.photobucket.com/albums/z...Main/MyBox.jpg
mptoledo is offline   Reply With Quote
