My friend's 997 does the same thing. I think it just indicates which key you used to open the car or have put into the ignition.
His car has seat memory, so depending which key you use, it automatically sets the driver's seat and rear view mirrors to the preset position.
Were you able to turn the ignition on? (all the warning lights should come on). Were you able to turn the key through the starter position?
If you can't turn the key, try giving the steering wheel a wiggle as you turn the key. It might be resting on the steering lock.
Hope that helps.
Cheers,
Sandy.
