My console is black and soft-toch material peeled off. I used scotch brite to strip what was left (it leaves plastic untouched for better texture). I then used SEM Landau Black interior spray paint ($12 in my local auto-paint store).
It looks brand new now.
Make sure you remove all the softtouch though.
P.S. Console is prety easy to remove. I remember there were a couple tricky screws (under storage compartment bottom, plastic just lifts off and exposes handbrake adjustments and screws, also - one under the change holder in the same storage compartment). couple under cigarette lighter and shifter. Lift carefully, there are wires attached.
Good luck. It can be all done in one day.
