Excellent idea with "fueling" and "pressure-checks." One item of importance: tire pressure mesurements will change significantly with temperature: Recommendations are to check the pressure cold and not at operating temperature(hot rubber). I have found as much as 4-5 psi increase on hot tires.
Mike -- be sure and have your tires balanced at very high speeds. Most tire stores balance around 60-70 mph. Need to have themn get the machine spinning at much higher (maybe 140-150-ish, hee hee)
