Old 07-30-2009, 06:34 AM   #2
Burg Boxster
All depends on which model h/u and the specs. For the most part though, they both should be active at the same time. So you should be able to wire the rear speakers off the h/u's high level outputs and be able to keep the sub connected to the line level outputs from it as well. You might have to change a setting in the set up but it should be ok.
Good luck
