Old 07-29-2009, 01:52 PM   #4
JFP in PA
You will lose very little oil when pulling off the filter canister. Just put something for it to drain into under the filter and you will be fine. I also would not try stretching the o-ring over the housing, plus if you loosened it, and there was already an o-ring there, you should not reuse it...........
