Old 07-29-2009, 12:08 PM   #2
mptoledo
You will have an oil leak................ Why not pull the housing back off and look to see if there is a gasket, and even if there is, replace it. You will lose very little, if any oil in the process and can top off your oil level, which is apparently low either due to the leak or because you underfilled it...............
thanks for the reply, I just did the oil change and have only started it twice for about 30 seconds each. zero oil leaks as of now. If I did put a gasket on, it was the new one that came with the filter.
If I unscrew the plastic filter cover won't oil come shooting out? at $5.5 a quart I would rather not waste it.
After thought, could I put the gasket on from the bottom and roll it up to the top and unscrew the housing just a little? The gasket is rubber and stretches. Anythoughts on this?
I'll take my Guns, Religion, and Money; You can keep the "CHANGE" B.O.!!
SO, GROW A PAIR NANCY AND DRIVE IT LIKE YOU STOLE IT!!
http://i826.photobucket.com/albums/z...Main/MyBox.jpg
mptoledo is offline   Reply With Quote
