Old 07-29-2009, 02:51 AM   #2
mmontfort
Ball Joints
Could be engine mount I haven't looked at it yet. It is the type of clunk that everyone here has described as the control arms and I did replace the bushings. It is only at slow speeds and is every bump I hit no matter how slow or how small the bump. At higher speeds it only happens when going over larger bumps. When I put the car on my lift and hammer away with a rubber mallet I can not find anything that makes noise. Since the suspension is not loaded that leads me to believe it is the suspension. Today I will beat (lightly) on it some more. The noise comes from both the right and left rear. Two isolated sounds independent of each other. Don't think that is the engine mount.
mmontfort is offline   Reply With Quote
