Slide your seat forward away from the rear engine cover, then raise the horizontal lever on the side and, while seated, use your body weight to push back and the seat should pivot to a lower position.
If this lever is missing you'll need to either replace it or find another way to disengage the height locking mechanism.
Make sure your seat back is not touching the carpeted panel behind the seat preventing it from lowering.
