Old 07-27-2009, 11:31 AM   #1
skates15
break pedal sounds like a spring is going to break
I have an 07 with 17K miles on it. It has been in the shop several times because the break pedal sounds like the tension on a spring or piston is going to break. Whenever I press down on the pedal it makes a creaky springs noise that the dealership said could not be fixed without replacing a pinion or something to that effect. They supposedly made an adjustment and the pedal is a bit easier to depress, however the sound is still there, which drives me nuts because it sounds like the pedal is going to break.
Anyone know if this is normal as the dealership in Albuquerque claims? I would think when you depress the break pedal it shouldn't make a noise.
Thanks for all your help.
skates15 is offline   Reply With Quote
