Heres a little trick (among a couple I used to get the car up. If you get one back wheel of the ground and let the wheel/suspension swing down, the drop it down easy, you'll have bought yourself am 1nch or 2.
I also use 2 floor jacks. a full size 3or 4 ton job and a $29 kragen mini floor jack. Use the cheapy to lift it enough from wherever you can, then put the big one where ever you want.
Regards, PK
