Old 07-26-2009, 09:35 AM   #13
pk2
Heres a little trick (among a couple I used to get the car up. If you get one back wheel of the ground and let the wheel/suspension swing down, the drop it down easy, you'll have bought yourself am 1nch or 2.
I also use 2 floor jacks. a full size 3or 4 ton job and a $29 kragen mini floor jack. Use the cheapy to lift it enough from wherever you can, then put the big one where ever you want.
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
