Old 07-25-2009, 07:54 PM   #2
chaabouni
Not much to it: remove the side carpet panels in the trunk by undoing 4 plastic screws ( 2 on each side). Then undo the wiring harness to to each light assembly. Each tail light is held with 4 bolts/nuts. Undo these and the light should slide right out. Good luck.
chaabouni is offline   Reply With Quote
