Old 07-24-2009, 09:07 PM   #8
Lil bastard
Lil bastard's Avatar
Originally Posted by Frank M
for the DIY to bleed a clutch slave with no shop equipment can be impossible sometimes.
Here is a sure fire way to do it with out a power bleeder.
  1. run a clear plastic line from a rear brake caliper bleeder to the clutch slave bleeder.
  2. be sure the brake master is full of fluid
  3. have someone depress the brake pedal and hold it, not to hard but hard enough to keep it depressed
  4. while they are holding the brake firm open the bleeder for the caliper and now open the bleeder for the clutch slave
  5. the brake pedal will go down and stop, air will bubble up into the clutch master reservoir
  6. close the caliper bleeder and refill the brake reservoir
  7. do the same procedure again, depress brake and hold, open bleeder and push fluid through clutch system in reverse
  8. do this for 5 or so times, each time keeping brake master cylinder full
  9. in essence you are reverse bleeding the clutch system
Why bother with all the in-between stuff?
Why not just reverse bleed it directly from the power bleeder to the slave bleed nipple and extract any excess fluid from the MC with a Turkey Baster?
This way you totally eliminate the possibility of introducing air into the brake system because you're not opening the brake master cylinder at all. They are two distinct systems.
Both the clutch and the brakes have their own separate master cylinders, the clutch master is low, behind the firewall opposite the clutch pedal. They only share a common fluid reservoir.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
