Old 07-24-2009, 05:20 PM   #11
TEX
Thumbs up maybe a solution
Originally Posted by J2da
Im also having the same exact problem here, and have replaced the air/oil sperator also. I cant seem to pinpoint the issue, could be piston rings or head gasket though. Hoping that isn't the issue but does anyone know where to start looking?
Finally after taking my car back to the dealer regarding the white smoke on accelleration ,which they said was due to quote "found to happen when driving with high transversal acceleration and high revs, solution is a Motor Sport oil seperator available to these conditions" ???
But as luck have it when I was about to pull out of there car park service area, I started the car and a HUGE PUFF of White smoke appeared that almost covered the carpark area!!
Lucky the head mechanic was there , he immediatly said it was a AOL seperator on the way out.
As I tried to tell them all along!!
Its booked in next week to replace the AOL ,so here is hopeing that this problem will finally be fixed.
Will give you update ASAP
Cheers all
TEX is offline   Reply With Quote
