Old 07-23-2009, 03:39 PM   #1
eightsandaces
Originally Posted by yimmy149
I need a new jack, if I'm going to go through the effort/expense, I'd like to get one that does not require the 2x4 method if possible.
The model I have has as flat a tongue as I've seen and it's still not low enough. It's an issue of going in from the rear to access the jack point and the distance to said jack point. By the time you approach it you're on the incline of the jack. Otherwise, the jack is more than capable of getting under the Boxster at all other points.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40105
eightsandaces is offline   Reply With Quote
