Old 07-20-2009, 02:44 PM   #2
eightsandaces
Originally Posted by timothy
Recently installed litronics (w/out control unit) and the right beam is pointing too far down. I already maxed out the manual adjustment. My guess is that the internal adjustment motor is stopped in a non-optimal location. Does that sound legit and is this something that would be fixed by installing a control unit?
No retrofit for the control module, make sure you are going in the correct direction, I found a set of factory directions that were the reverse of the way my litronics adjusted. It's hard to conceive of you being at the high limit and still pointing low.
PS Make sure to follow the rest of the factory directions regarding weighting the divers seat and distance from overhead door you are using as projection screen.
eightsandaces is offline   Reply With Quote
