Old 07-17-2009, 10:12 AM   #1
mptoledo
Originally Posted by eightsandaces
If it's not under warranty, I would:
1) attach wire, hold in place, confirm that the defroster works when the circut is re connected.
2) assuming it does, depending on the connection (never seen one) I would first try to solder it. (carefully since the top is close by) if not...
3)epoxy it, make sure you don't use too much product which could cover the contacts you are attempting to connect.
I agree with eightsandaces for the fix, but he stated its under warranty. I am sure epoxy will work. Sodering would be my first choice, but who knows what the yahoos will screw up. If they only put in a new window in, it might not be as water tight or secure as the factory. I think your best bet is to make sure it works after they fix it. Unless your top is in bad shape I wouldn't press for a new top. It could open a new can of worms with fit and finish. (just my 2 cents).
I'll take my Guns, Religion, and Money; You can keep the "CHANGE" B.O.!!
SO, GROW A PAIR NANCY AND DRIVE IT LIKE YOU STOLE IT!!
http://i826.photobucket.com/albums/z...Main/MyBox.jpg
mptoledo is offline   Reply With Quote
