Old 07-17-2009, 08:41 AM   #3
eightsandaces
If it's not under warranty, I would:
1) attach wire, hold in place, confirm that the defroster works when the circut is re connected.
2) assuming it does, depending on the connection (never seen one) I would first try to solder it. (carefully since the top is close by) if not...
3)epoxy it, make sure you don't use too much product which could cover the contacts you are attempting to connect.
eightsandaces is offline   Reply With Quote
