I can answer a couple of those for you.
My Box's dashboard and top creaks just a little when I'm turning, especially if I'm turning at a higher speed. I think that's normal, or we may be in the same boat.
The seat's height can be adjusted, there is a lever on the side of your seat (I'm guessing you have an electrically adjustable seat), pull it while sitting on the seat and it should go down.
My brakes screech as well, it could be brake dust. Try washing the brakes the next time you clean your car, and see if that helps.
