Old 07-15-2009, 11:11 AM   #3
JFP in PA
Originally Posted by urban_legend
Going back and forth b/w kilo and miles each start-up. And some freezing - gas and oil warning lights on with no movement of the speedometer.
A light tap to the top or face of the cluster fixes it for a time. Should I just swap out the cluster, check wiring, any suggestions?
Also for a 2001 cluster - what other MYs will work? Part number?
996641 213 00?
Are you having any issues with your ignition switch? Similar problems have been seen when the switch was on its way out............
