Dang stupid obstacles
I would go see and eye doctor or you need to slow down to under 50 before you make a gas turn. Glad you didn't take out the pump. Anyway sorry for your mishap. If you hit the obstruction with the wheel you could have bent the rim and you should be able to see this problem. Lower control arm made of aluminum does not take and impact very well either. If there is no body damage get a machanic to look at it first to see what has been damaged. :ah:
