Old 07-08-2009, 11:56 AM   #2
70Sixter
If you popped plastic covers off and there was a hole there, it sounds like the spinlocks are installed. Altho I do not know why they would be unless your car came with Speedster humps or a hardtop. And I am not sure what it looks like w/o the locks.
The rear top levers should engage when you rotate them all the way back toward the centerline of the car. As pschaub said you should definitely feel the engagement.
Then you lock the front down after the rear is secure. Your rear locks might just require adjustment. Let's hope.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
